Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
    Second Battery is pretty easy, i used the bep dual vsr plus switch i have a site you can get it for a 100.00. (no remote wire) like the blue seas but Razz is the the man when is comes to this stuff. he's "the Razzman and we have the Sandman "
    Thanks JM. What's the difference between what you have and the Blue Sea unit that razz has?
    I already have a Blue Sea battery switch (bought earlier this summer but have not installed it) so I just need the ACR. I am having a little trouble finding a place that sells just the ACR but I haven't looked too hard yet.
    Al,
    The Blue seas has a ground, ignition and led wire to hook up as well as the two positives. If you have the blue seas switch i would go with that.
    http://www.westmarine.com/1/3/blue-s...ners-isolators
    FYI
    http://www.bepmarine.com/Single-Engi...0.html#details
    http://www.keenzo.com/showproduct.asp?ID=3139863
    Aug 2009
    Montana
    I'll get you a list together along with pics.
    Razzman,
    If it's not too much bother I'd like to get your list and directions as well?
    I've been to your profile and looked at all your pics. I've decided I like the BlueSea setup and going to be adding a second batter this winter as well during my stereo upgrade. I have a Outback DD so in same boat (pardon the pun) as Cab with not alot of room.
    I'm comfortable with all the stereo install but the dual battery thing is new to me!
    I get lost in the ACR, isolator, switch........ect. All I know is I want to separate the power to stereo, amps, & accessories from the cranking battery, have all the essentials be able to run in an emergency (like the bilge and starter if first batt runs dead due to too much tunes and beverages, & have them both charge while running. Also, any little shortcuts or additions such as power inverter wired up or trickle charger to make life easier I'm open to that as well.
    Thanks again for all your expertise.
  4. #24
    Al,
    FYI
    JM,
    Thanks for the link to keenzo. They have the Blue Sea ACR for $77 which is the cheapest I've seen so far.
  5. #25
    Aug 2009
    Montana
    JM,
    Cab,
    I see it on there for $103.50?
  6. #26
    Cab,
    Here's the link to the Blue Sea ACR only (I already have the switch) for $76.61:
    http://www.keenzo.com/showproduct.asp?ID=2939479
  7. #27
    cool, glad to help.
    joe
    Aug 2009
    Montana
    Default Blue Seas products
    Hey all,
    I found the best prices so far on BlueSeas products:
    Here's a link to the relay:
    http://www.manventureoutpost.com/pro...287610%29.html
    Here's a link to the "add a battery"
    http://www.manventureoutpost.com/pro...287650%29.html
