Although I love my 02 Outback (direct drive), I seem to scrape the trailer at every gas station driveway, and cannot get up my own. Are any of you baffled by the lack of clearance of the rear sway bar under the prop, or is it just me? I\'d love to get the boat up my dirveway and into my garage. Please help!
Results 1 to 10 of 13
05-13-2004, 09:35 AM #1
Junior Member
- Feb 2004
- Madison, Wisconsin
- 8
Trailer ground clearance-Need Help!
John
2002 Outback
05-13-2004, 09:49 AM #2
Senior Member
- Oct 2003
- Northern Kentucky
- 110
Replying to Topic 'Trailer ground clearance-Need Help!'
I had the same issue. What I did was take a 2X12, cut in half, and use it as a ramp. I back the trailer until the prop guard on it starts to drag, then I slide the ramps under it and it provides enough clearance to get over the hump. FYI, I also stick these in my truck anytime I leave the house with the boat attached. Got stuck in a restaurant once with a terrible driveway.
05-13-2004, 12:59 PM #3
Member
- Jan 2003
- Nashville
- 57
I do not have this problem but I have heard of people mounting small wheels to the prop guard. Check the boat discussions on wakeworld.com. I have seen pictures on that message board of what others have done.
05-13-2004, 09:02 PM #4
You guys must be towing your boats with the front too high.
jy
05-14-2004, 12:29 AM #5
Junior Member
- Jan 2004
- ARLINGTON, TEXAS
- 23
John, take a look at the axles under your trailer. The axles that Boatmate (the company that builds the trailers for Skiers Choice) uses are UFP torsion axles. UFP's torsion axles are adjustable height suspension, and they are set at about 10 degrees above level. That means that the frame of the trailer sits lower to the ground. A torsion axle has the suspension built into the axle (no springs). What makes UFP's adjustable ride height is that there is a splined bar coming out of the main axle tube. The trail arm, which holds the spindle, hub, rotor and caliper, fits onto this splined shaft. The trail arm has a bolt and nut which is used to tighten this arm to the shaft. All of that is stated to say this. You can gain more ground clearance by changing the angle of the trail arm. There are a couple of problems with doing this. Number one, you will have to back your trailer deeper into the water to load and unload your boat. Number two, your trailer may not look quite as good as it did. The reason for this, is you could get too much clearance between your tire and fender depending on how much you change the angle of the trail. I personally have never changed the setting on one of these axles, but I manage a trailer parts distribution warehouse and I am very familiar with this concept. For what it is worth, that is a little more permanant solution than some of the other things you could do.
Later,
Mike
05-14-2004, 06:54 AM #6
Senior Member
- Oct 2003
- Northern Kentucky
- 110
That's what I thought too, James, so I went and purchased a different hitch with a much lower tow angle. That solved my issue in the back, but then my hitch drug, so I had the same issue.
Hey Mike, I would like to hear a little more detail on your solution. Can that be done with the boat on the trailer, or have to be off?
05-14-2004, 11:29 AM #7Guest
It can be done either way. I would think though that it would be much easier with the boat off of the trailer. Either way, you will have to jack the trailer completely off of the ground to accomplish this move. The other thing is, the lighter you make the end unit, like removing the tire and wheel assembly, the easier this will be. I spoke with the plant manager at Boat Mate this a.m. to make sure that my information was correct, and it was. Each spline that you rotate the swing arm down will be approximately 6 degrees of rotation, that should be somewhere in the neighborhood of .6" to .75" per spline moved. Again, the two things that you have to remember are you will have to back the trailer a little farther down the boat ramp to load and unload and you are going to add clearance between the top of your tire and the underside of your fender. However, if this solves your problem, an extra 3/4" of clearance there will not look too bad. If you don't like it, you can always change it back. If you have any further questions, I would be glad to help.
Later,
Mike
05-14-2004, 01:07 PM #8
Junior Member
- Jan 2004
- ARLINGTON, TEXAS
- 23
It can be done either way. I would think though that it would be much easier with the boat off of the trailer. Either way, you will have to lift (either with jacks or a lift) the trailer completely off of the ground to accomplish this move. The other thing is, the lighter you make the end unit, like removing the tire and wheel assembly, the easier this will be. I spoke with the plant manager at Boat Mate this a.m. to make sure that my information was correct, and it was. Each spline that you rotate the swing arm down will be approximately 6 degrees of rotation, that should be somewhere in the neighborhood of .6" to .75" per spline moved. Again, the two things that you have to remember are you will have to back the trailer a little farther down the boat ramp to load and unload and you are going to add clearance between the top of your tire and the underside of your fender. However, if this solves your problem, an extra 3/4" of clearance there will not look too bad. If you don't like it, you can always change it back. If you have any further questions, I would be glad to help.
Later,
Mike
05-14-2004, 03:34 PM #9
Junior Member
- Feb 2004
- 8
Thanks alot, Mike. I would like to try your option before adding wheels since the lower draw bar and ramps have not enabled me to get up the driveway. Unfortunately I'm really quite ignorant when it comes to mechanical terms and experience fixing my boat, so if you could help me out with a bit more information I would appreciate it. If I am correctly identifying the nut and bolt to which you refer, there are no additional brackets or holes to re-bolt it to. So by "splined", do you mean that once this assembly is loose there will be revealed some notches/additional settings to adjust the attitude of the trail arm?
John
2002 Outback
05-14-2004, 05:03 PM #10
Junior Member
- Jan 2004
- ARLINGTON, TEXAS
- 23
Yes, when this trail arm is removed there will be notches on the inner shaft that you can use to switch the angle on. If you would like to talk to me, the company I work for is Redneck Trailer Supplies in Arlington, Texas. You can give me a call at (817) 468-2626 and ask for Mike. We are open 8:00am to 5:00p.m. CST Monday through Friday. If you would like to talk to me about it this weekend, you can send me an e-mail at 4olivers@comcast.net, and leave me a name, phone number and good time to call and I will do the best I can to talk you through this. As I said, I have never done this myself, but I am very familiar with how it works and what has to be done.
Prop and Fin Clearance?
By jmvotto in forum General ChatReplies: 16Last Post: 05-07-2008, 08:48 PM -
Trailer little running (clearance) lights
By moomba_armada in forum Sales & InformationReplies: 2Last Post: 04-14-2008, 08:23 AM -
Trailer hitch hight of single axle Outback Trailer
By Laz in forum Boat OwnersReplies: 46Last Post: 01-05-2008, 12:53 AM -
XLV Bridge Clearance
By Zemp-XLV in forum Boat OwnersReplies: 5Last Post: 05-28-2005, 11:04 AM -
Ground wire location
By Jon in forum Service & RepairReplies: 4Last Post: 04-26-2003, 06:09 PM
