#1
Old 09-02-2005, 10:15 AM
clark clark is offline
Senior Member
Default Loose tower bolts
Make sure to check all of your tower bolts. They may seem to be OK from checking the outside by tightening with a phillips screwdriver, but don't trust that alone. Not a single nut was tightened all the way and some of them I could turn with my fingers. I just bought the boat new this year. Surely wakeboarding hasn't loosened them that much. You will need an 11MM deep well socket.
Clark
  #2
Old 09-02-2005, 11:45 AM
Buttafewcoe's Avatar
Buttafewcoe Buttafewcoe is offline
Senior Member
Default Replying to Topic 'Loose tower bolts'
But do not overtighten or we will be seeing cracks in the gelcoat.
Hope this helps
Butta
__________________
  #3
Old 09-02-2005, 03:21 PM
smokedog2 smokedog2 is offline
Senior Member
Send a message via Skype™ to smokedog2
yep, mine were loose as well mis summer but I had checked them new and semi regular and I believe they did work loose. I tried to get them tight but not too tight, I was afraid too tight might also crack the gel coat. Anyone have some torque advice here?
oops distracted for hours and Butta beat me.
SD2
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Breaking tower bolts deeluk Service & Repair 3 06-25-2007 05:49 PM
Swim platform mount bolts stripped Ghostrider Service & Repair 4 08-02-2006 12:59 AM
Loose Bolts in Upholstery!! mobiusLSV05 Service & Repair 9 07-30-2005 06:13 PM
Tower bolt vibrated loose from tower! sailnfast Service & Repair 6 05-20-2005 02:21 PM
Rad-a-cage bolts BensonWdby Service & Repair 0 07-28-2004 11:05 PM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
