Go Back   Moomba Boards > Moomba Boats > Boat Owners
Reply
Thread Tools Display Modes
  #1
Old 07-07-2006, 01:04 PM
Longshore Longshore is offline
Junior Member
Default Opinions on 310 HP
Hey Everybody,
Sorry for these dumb questions but I'm newer to boating and want to make sure I buy the right stuff. I'm assuming the standard 310 hp engine in Outback V is ok. Is it necessary or worth considering more hp? Thanks again.
  #2
Old 07-07-2006, 01:35 PM
YellowMoomba0 YellowMoomba0 is offline
Senior Member
Default Replying to Topic 'Opinions on 310 HP'
I have the 04 Outback with the carb and the 310 hp is definately sufficient. The upgrade would be nice because fuel injection is always more efficient on gas and operates smoother and as a bonus you get more hp. More hp is more hp which, for the different size boats and different activities is debateable as to how much is needed.
I have had to tweak my carb rich/lean and idle screw settings. I had rather have the fuel injection as a personal preference with boat operation being the main issue over more hp. Inboards in general are designed for the pull of skiers instead of overall top end. I kneeboard, ski the course, float, cruise around and so far I have never blamed a lack of hp on anything that went wrong.
__________________
I mess with Texas
  #3
Old 07-07-2006, 01:38 PM
Livindadream Livindadream is offline
Senior Member
SD2 in 1..2..3..
I have a carb, and only complaint I have with boat. Own an '02 Mobius, and wish I had the EFI. I am going to see the fine boys at Lakota Watersports this weekend about a new one, and will not buy w/out. If you wakeboard or have small children that play at lower speeds, do not leave the dealer without perfect pass.
  #4
Old 07-07-2006, 02:19 PM
smokedog2 smokedog2 is offline
Senior Member
Send a message via Skype™ to smokedog2
yep,
Gotta have fuel injection. You cannot even buy a car without it.
You will save the money in fuel and resale value. FI is one of the top 5 things most valued in a used boat. Plus - much lower tinker factor.
Say high to George for me. Tell him Brandon tore up the wake last weekend. He was clearly using the instruction he got June 25th.
Are you going to the dark side (Supra)?
Ditto PP and heaters, heaters are big if you want to stay on the water with the little ones.
Dual batteries will be my next boat addition.
SD2
  #5
Old 07-07-2006, 04:36 PM
Senior Member
This guy lives in Arizona. He could use the heater for cooling, I suppose. Supra? Nope, still too tight to do that, although he does have a couple really sweet ones. Think I'm going Mobius LSV, but he has a great deal right now on a DD '06 LS. May have him order one, as I do not need a trailer.
  #6
Old 07-07-2006, 11:44 PM
Senior Member
Ok,
Thread hijacking –
Will Arizona wish he had a heater before or after LDD wishes he had a trailer?
My money is on the heater but LDD could need the 20 hour servicing before AZ has a cold morning. It will be close.
SD2
  #7
Old 07-08-2006, 07:11 AM
qb12 qb12 is offline
Senior Member
sd2, what is this dark side you talk about
I had a 310 carbed on my outback. Never really had any troubles with it. Just a little more stubborn to start on first outing of the day.
Went to the 325 efi and wow what a difference. It starts much better and I agree with the resale.
db
  #8
Old 07-10-2006, 05:20 PM
Sharru-Kinu Sharru-Kinu is offline
Junior Member
I ride year-round in the Phoenix area and the heater is a must for six months out of the year and for the other six - you actually foget that it is there.
Get EFI. Get the tandem trailer. And get it all from Dan Lee at Surfside Boat Center in Tempe. My 2c.
__________________
'06 Mobius LSV.
  #9
Old 07-10-2006, 07:03 PM
Senior Member
1c each
  #10
Old 07-11-2006, 01:06 AM
BensonWdby's Avatar
BensonWdby BensonWdby is offline
Senior Member
Have a 310 carb in 99 Mobius and runs with out much trouble. Pulled 8 skiers out of the water last weekend with 3 adults in boat.
Dave
__________________
http://bensonwdby.home.comcast.net/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Looking for opinions on good beginner board.... AaronWhitt82 Wakeboarding 4 09-13-2007 05:22 PM
Opinions on a '98 Mobius? MOOMBA_97 General Chat 7 12-27-2006 10:28 PM
Need your opinions AZHeet General Chat 5 09-26-2006 01:57 PM
Looking for insider opinions TimGT3 Boat Owners 14 04-29-2006 09:16 PM
Need opinions ben624 General Chat 9 05-12-2005 01:52 PM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
