#1
Has anyone installed one of the Flushpro devices to their boat? Does it work well? Have any experience with it restricting cooling water flow during normal operation?
http://www.overtons.com/modperl/over...5608&fcat=[url=Flushpro] |
#2
i have installed a Flush pro, It works great and I have had it for 3 years. it does not restrict water flow. it is also very cool cause you can flush while sitting in salt water.
#3
Concur with Deepcove. Has worked great.
#4
I got the Flush Pro that is referenced in the link in this post. For some reason, I assumed it had water hose fittings on it like the inline quick disconnect. Do you cut a hose to attached to this? Any help or suggestions will be appreciated...
BW |
#5
You have to cut your intake hose and connect onto either side of the flush pro with hose clamps ( on each end horizontally in the link picture). From there you can install a quick connect onto the hose attachment ( the connection at the top looking at the link picture). it's all quite easy.
#6
Thanks Deepcove,
I finally realized I had to cut the main water line.. survived it, although I then realized that when I winterized, my seal on impeller housing was not as tight as it once was. Got a new one ordered and will install soon. BW |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Flushing manifolds? | TL7 | Service & Repair | 2 | 04-19-2008 09:45 AM |
| Which engine do I go with? | ucandoit | General Chat | 16 | 07-04-2007 03:43 PM |
| Engine ID: 325 vs 340 HP MPI | Ian Brantford | Sales & Information | 9 | 05-31-2005 02:36 PM |
| Engine bog down | Yellowmobius | General Chat | 2 | 07-28-2003 02:45 PM |
| engine | jqrk | Service & Repair | 5 | 07-22-2003 03:21 PM |
Linear Mode
