#1
Old 07-25-2007, 12:01 AM
MoMan MoMan is offline
Junior Member
Default Oil Bath Wheel Bearing Leak
Hi,
I have a 06' LSV with Boatmate trailer. It has a "Reliable" brand oil bath wheel bearing lubrication system. Unfortunately I have developed a leak where the cap connects to the hub. I can't tell if this is a screw on cap or a press fit cap. Does anyone have maintanance documetation on this system. I just discovered that the boat came with Trailer Buddy bearing documentation but that is not what is on the trailer. The Reliable website does not have any information on the oil bath system. I have contacted them.
Dave
  #2
Old 07-25-2007, 06:27 AM
Buttafewcoe's Avatar
Buttafewcoe Buttafewcoe is offline
Senior Member
I believe that's a press on. But I've been wrong before.
B
  #3
Old 07-26-2007, 01:27 AM
JoeTechie JoeTechie is offline
Senior Member
If I remember correctly....If it is the clear plastic, it is screw on, if it is metal cover it is press fit.
I'll get the manuals out in the am and make sure. It gives some odd truck wrench tool to take them off is they are screw off.
-J
  #4
Old 07-26-2007, 08:23 PM
Junior Member
Yes it is the clear plastic style hub cap.
  #5
Old 07-27-2007, 02:48 AM
Senior Member
I scanned the pages for you.
http://joetechie.com/moomba/p1.pdf
http://joetechie.com/moomba/p2.pdf
-Joe
  #6
Old 07-31-2007, 08:59 PM
Junior Member
Thanks Everyone,
As it turns out the cap cracked off the hub. Since you can see the threads I am now certain that it is a threaded plastic. As it turns out all the caps show cracking, so I am replacing all of them. The replacements are aluminum. The instructions will come in very handy. Thanks a ton.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
wheel bearing leaking moombadaze Service & Repair 13 04-30-2008 12:02 AM
Strut bearing rosh General Chat 0 05-03-2007 08:25 PM
Oil Bath Hubs YellowMoomba0 Service & Repair 16 11-21-2006 11:22 AM
Trailer bearing and hubs tn_viper General Chat 0 09-09-2003 07:39 PM
Drive shaft Strut bearing Yellowmobius General Chat 5 09-08-2003 07:16 AM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
