Go Back   Moomba Boards > Moomba Boats > Service & Repair
Reply
Thread Tools Display Modes
  #1
Old 08-09-2007, 12:12 PM
CraigB CraigB is offline
Junior Member
Default Replacing rear ballast evac pump
What's the trick for accessing the rear evac pump? Has anyone replaced theirs?
Thanks,
C
  #2
Old 08-09-2007, 02:16 PM
JesseC's Avatar
JesseC JesseC is offline
Senior Member
What year and model boat do you have?
__________________
02 LSV
Projects Main
Tower Speakers
Hull Speaker
  #3
Old 08-09-2007, 10:01 PM
Junior Member
It's a 2004 XLV (Gravity Games Edition).
  #4
Old 08-20-2007, 03:58 PM
Junior Member
It looks like you might have to remove the rear cover plate and exhaust manifold. How difficult is it to remove the exhaust manifold?
Any help would be greatly appreciated. The shop wants to charge a bunch for a simple job. I'm guessing it just takes some time tearing things apart and putting them back together.
Thanks,
C
  #5
Old 08-20-2007, 04:54 PM
JesseC's Avatar
Senior Member
I would try everything I could to not have to remove an exhaust manifold!! I know that mine are really dug in, but I have changed all three of mine. The port side and front ones are easy, but the starboard one is a pain. In my LSV, the trans cooler and manifold are in the way. I am not sure about an XLV. If you are running the same pumps as mine, the top of the bracket has a hose that you can take off, then unscrew the "cap" and the pump will fall into the bottom of the boat. Retrieve the pump, cut the wires. Solder in the new one and reverse the first few steps.
__________________
02 LSV
Projects Main
Tower Speakers
Hull Speaker
  #6
Old 08-20-2007, 04:59 PM
Junior Member
You're right it's really tight. I appreciate the response and info on the manifold, looks to be difficult to remove. I'll give it a try.
Thanks,
C
  #7
Old 08-20-2007, 05:09 PM
JesseC's Avatar
Senior Member
Here is a photo of what the ones I am fimiliar with look like. I replaced them with the ones that you can just take the "pump" loose with some snaps and leave the housing in place. Leave enough wire that you can do this again in the future. Trust me you will be doing this again. It's just the way it is. In the photo, I have taken the hose off of the trans cooler (the large water hose, not the trans line) and moved it out of the way. Then I removed the hose and unscrewed the "cap" where the red arrow is and fished the pump out by following the electrical wires at the stern of the boat. Hope this helps.
__________________
02 LSV
Projects Main
Tower Speakers
Hull Speaker
  #8
Old 08-20-2007, 05:17 PM
Junior Member
Yes, very helpful, just not easy to reach this particular pump as it is directly behind the exhaust manifold. There is a cover plate protecting the blower intake that can be removed that might give me access from above. So, I will try that first.
Thanks for the info.
Craig
  #9
Old 08-24-2007, 07:45 PM
Rugburn Rugburn is offline
Senior Member
I wonder why the factory doesnt put all three pumps on one board, kind of like you see on the make-a-wake.com website. That way you can access them easily and upgrade if necessary.
__________________
Jim Hagen
Madison, Wisconsin
jim(at)sign-edge.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Rear ballast not emptying WaterDawg Service & Repair 4 10-30-2007 06:26 PM
Rear Ballast Sac Filling Up mhaneke Service & Repair 3 07-09-2007 11:33 PM
replacing bilge pump hwb06 General Chat 7 04-16-2007 12:32 AM
Are rear ballast necessary on a Mobius LSV clark General Chat 16 10-20-2004 01:09 PM
Replacing the 250 lb factory ballast bags flynng Wakeboarding 1 08-15-2004 10:53 PM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
