#1
Old 09-01-2008, 02:16 PM
ffmcdou ffmcdou is offline
Junior Member
Default Wakesurf.....Ballast
I have a 2008 LSV with the gravity 3 ballast system. I would like to replace the passenger rear bag with the biggest one I can get back there, any thoughts? Also, how much does the stock bag hold? (weight)
Thanks.
  #2
Old 09-01-2008, 02:55 PM
deafgoose's Avatar
deafgoose deafgoose is online now
Senior Member
Quote:
Thanks.
The OEM bag is 400lb and you can replace it with a 750lb bag no problem.
__________________
2008 Outback V - gravity III ballasts, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package a, graphics package e, appearance package, cockpit & tonneau cover, black stainless rubrail, 14.25x14.0 prop.
Toys: Ronix Mana 134 with Kai bindings, Phase5 Drew Danielo Pro, Straight Line Sumo Sac 750lb, 450lb, 125lb ballast.
  #3
Old 09-01-2008, 04:19 PM
04OUTBACK's Avatar
04OUTBACK 04OUTBACK is offline
Senior Member
Send a message via Skype™ to 04OUTBACK
definitely the 750
Pro X Series Fat Sac™ - W707
dimensions: 50 x 20 x 20 weight: 750 lbs. / 340 kg.
Make sure you get the quick disconnect fittings for your fill and drain on the new sac.. that way, you can quickly remove the 400 and put the 750 in place.
I have 06 LSV and have 750s in the rear lockers. Once, I moved the starboard 750 to the port side seat and filled it about halfway and we got a smokin wave.
If you get 750, you could get a tsunami pump and fill the 400 up on the seat.
TIP: take the center back seat and turn it sideways so it sits next to the port side seat and that provides support for the fat sac..
cheers.
__________________
Brad
06 Mobius LSV
Conesus Lake, NY
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
