#1
Old 11-01-2008, 07:01 PM
stylinryan stylinryan is offline
Junior Member
Post Fuel pump issue
Need help! On my second fuel pump and I still cant seem to get the engine to run consistantly. Fuel pump is not feeding fuel into the carb.
It cycles good, but won't pull any fuel. Hitting it on the side with a wrench seems to work occasionally. Is it something else in the line? Air leak, bad fuel line? Do I need to install a check valve?
2005 Outback 310hp carb.
Tx
  #2
Old 11-07-2008, 04:28 PM
snowboardcorey's Avatar
snowboardcorey snowboardcorey is offline
Senior Member
Are you sure its the pump? Have you checked the fuel pressure with a gauge? Does it happen all the time or just when its hot?
  #3
Old 07-26-2010, 11:25 PM
Junior Member
It was the power valve in the carb!
  #4
Old 07-27-2010, 12:57 AM
AaronWhitt82's Avatar
AaronWhitt82 AaronWhitt82 is offline
Senior Member
Send a message via AIM to AaronWhitt82
Glad ya got her fixed !!!!
__________________
'99 Outback (Maroon/Creme) GM 350/Holley 4150
410 HRS
LaSalle-Peru, IL
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
